show instant-port ports
show instant-port ports [port_list | all] {profile profile_name {device-type device_type_name}}
Description
Displays Instant Port port information.
Syntax Description
port_list Specifies the Instant Port ports list.
all Specifies to show all ports.
profile Specifies to the Instant Port profile.
profile_name Specifies the profile name.
device_type Specifies the Instant Port device type.
device_type_name Specifies the Instant Port device type name.
Default
N/A.
Usage Guidelines
This command allows you to troubleshoot the configured Instant Port ports.
The following example shows Instant Port port information for all ports:
# show instant-port ports all
Port        Profile                          Matched Device                   Matched MAC Addr
1           Test                             PCs                              00:01:02:03:04:00
                                             PCs                              00:01:02:03:04:01
                                             PCs                              00:01:02:03:04:02
                                             PCs                              00:01:02:03:04:03
                                             PCs                              00:01:02:03:04:04
                                             PCs                              00:01:02:03:04:05
                                             PCs                              00:01:02:03:04:06
                                             PCs                              00:01:02:03:04:07
                                             PCs                              00:01:02:03:04:08
                                             PCs                              00:01:02:03:04:09
2           Test
This command was first available in version 32.6.2.
Platform Availability
